3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
[:@]My 2005 ram 4x4 is making a loud sqeaking sound from the left side when i turn the wheels. Its not coming form the tires I think its the upper ball joint. Anyone else have a similar problem? By the way my truck has 4500 miles on it.
I had that same problem.. but it was my lower. I took it to the dealership and it was all warranty work. They ended up replacing all 4 while it was in. Problem solved.
My 94 ram 1500 2wd was sqeaking and it was ball joints had no grease fittings so could not grease it durring the time i had it. need to see if my 04 ram has fittings if not they will not last long ether.
