Removing factory stereo from 2006 ram
Old Jun 9, 2006 | 01:21 AM
lerouxma's Avatar
lerouxma
Default Removing factory stereo from 2006 ram
Hello,
I am looking for instructions on removing my factory stereo in my 2006 Dodge Ram quad cab.
If anyone has a website with illustrations or not or if you have done it and want to tell me the steps it would be great.
I am installing a Clarion dxz665mp.
Old Jun 9, 2006 | 10:01 PM
Stroker's Avatar
Stroker
Default RE: Removing factory stereo from 2006 ram
I'f you can find out if the interior is the same in an 04 I can help you with this one. I think the cover just pulled off but I need to look ther might be one or two screws. Its been 2 years since I did mine after all.
Old Jun 10, 2006 | 06:41 AM
DubadubDodge's Avatar
DubadubDodge
The best advice I ever got about working around stereo in my truck was to let somebody else do it. Unless you've got alot of experience the difference in quality will be huge especially with complicated installs. (head, two amps, speakers, subs, XM) Anyway I know thats not really helpful but if you decide to do it i wish you luck.
Old Jun 11, 2006 | 06:02 PM
srenken's Avatar
srenken
Open the ash tray, and remove the two screws that hold the center stack bezel in place. The just pull the bezel away from the IP. The radio is held in place by four screws. What radio do you plan on replacing it with? The 2006 radios are CANBus radios. If you remove the radio, you will set fault codes for improper module configured on the CANBus. Proceed with caution.
Old Jun 12, 2006 | 11:25 AM
Devster's Avatar
Devster
What do u mean CANBus? I am looking to install a kenwood video system in my 06 Quad. What do i need to let the installer know about doing the install?
Old Jun 12, 2006 | 12:09 PM
lerouxma's Avatar
lerouxma
Should I only be concerned if I have steering wheel controls.
I went to www.canbus.us and it explains that it is a chip for multifunction or something.
Marc
Old Jun 12, 2006 | 12:11 PM
srenken's Avatar
srenken
The company doing the install should be familar with the 2006 Dodge Ram. CANBus is the communication protocol that replaced the J-1850. The CANBus needs to be configured based on the number of modules connected to the bus. This is done in the TIPM (fuse box). You will need a diagnostic tool that is capable of CANBus communication. As long as your aftermarket device does not connect to the bus, and you are not removing anything from the bus, you will be fine.
Old Jun 12, 2006 | 09:54 PM
lerouxma's Avatar
lerouxma
Thanks for the info I will be sure to look into it.
Marc
