leak in roof of cab?
Old Jun 14, 2006 | 12:35 AM
sweebs's Avatar
sweebs
Default leak in roof of cab?
anyone else experience this? the other morning after having rained over night, there was water dripping from the plastic visor retaining clip on the pass-side. My 1st guess would be that water is getting in through a marker light since I know of no other holes or anything on the roof. Just wondering if this is a known problem or what?
Old Jun 14, 2006 | 01:54 AM
Ramsport_03's Avatar
Ramsport_03
Default RE: leak in roof of cab?
[&:] my 03 had a slight leak where the grab handle is on the drivers side. dealer took it off and just resealed the attachment holes.
whatever it was is gone now.... [:@]
Old Jun 15, 2006 | 04:39 PM
osteodoc08's Avatar
osteodoc08
There are TSB's for the grab handle leak and the roof mounted light leaks. Both are sealing issues. A little dab of silicone and the problem is solved.
Old Jun 16, 2006 | 07:46 AM
Ramman21's Avatar
Ramman21
I have posted this on other threads but here we go again. If you are not sure where the source of the leak is (door seals, ect...) go to the local grocery store and ask for a block of dry ice... roll all windows up and place ice in small bucket and pour water over the ice. Place the bucket on a towel and shut the doors. Eventually the fog will seep through and holes in the cab. You cant always tell where the leak is by where the water falls. There is always the possibility or the water running before it drops. Good luck man
