sea foam & TB Cleaning
Old Jun 15, 2006 | 03:18 AM
eatsleepdrivesc's Avatar
eatsleepdrivesc
Default sea foam & TB Cleaning
Hey yall,
Well went today to the local parts store and got two cans of sea foam one of them is for me and one for my moms car, well can someone here give me a break down of what to do exactly to yield the best results with this cleaning for my ram..
Next questions would be the same thing for a TB cleaning would like the break down to get this done.
Thanks for any and all help
Old Jun 15, 2006 | 06:27 PM
helrod's Avatar
helrod
Default RE: sea foam & TB Cleaning
GO TO THEIR WEB SITE, THEY HAVE THE INSTRUCTIONS FOR ALL THE DIFFERENT WAYS TO USE . I JUST PUT A CAN INTO MY TANK TODAY TO SEE IF IT HELPS THE BAD IDE AND STALLING.
Old Jun 17, 2006 | 10:28 PM
eatsleepdrivesc
Default RE: sea foam cleaning
well guys i did the sea foam to my truck today, really easy to use just un-hook the vaccum line that is attached to the brake booster, with the engine warm and running just pour it in slowly and the bottle says use about 1/3 of a pint. do that then turn it off for about 5 minutes and then start back up and it will blow smoke out the tail pipe and you have cleaned your engine. WELL, did all that and guess what i only got one puff of smoke and let it run for 10 minutes after that and nothing at all so my engine must not of had anything in it. i really wasnt expecting this, i may just chock this off to that i only your premium gas (93) from chevron, and i run injector cleaners every once in a while. So while i was disappointed in my truck but they happy because their wasnt really anything to clean out i went to my moms 97 camry and man did that think smoke, it smoke for about 10 minutes. That put a smile on my face to see finally a lot of smoke. and my friend was over while i was doing this so we did his 2000 ram 1500 with the 5.2 his smoked for about 4 minutes and then his quit. well i think im done
Old Jun 18, 2006 | 01:09 AM
osteodoc08's Avatar
osteodoc08
Glad it worked out for you. Sea foam is great stuff. How are all the engines running now? Any improvement?
Old Jun 18, 2006 | 01:19 AM
eatsleepdrivesc
they all seem to be running better, mine has a better idle, moms car feels like it has some more power in the mid rpm's and my friends truck he said it feel that it is more responsive, so i would consider it all good in the neighborhood, i will post some pics of it being done on mine and my moms
Old Jun 18, 2006 | 01:56 AM
eatsleepdrivesc
PICS
Old Jun 18, 2006 | 03:55 AM
backdraft98's Avatar
backdraft98
I have also used the Sea Foam. It is great stuff. It really works. Mine only smoked a lottle but it did smoke. I fugure it probably wasnt that dirty. I put it in all my gas powered stuff, mower, 4 wheeler.
