radio
Old Jun 15, 2006 | 11:56 AM
helrod's Avatar
helrod
Default radio
DOES ANYONE KNOW HOW TO GET THE DASH PANELS OFF TO GET TO THE RADIO MOUNTS ON AN 03 1500 ???
Old Jun 15, 2006 | 06:20 PM
HemiLonestar's Avatar
HemiLonestar
Default RE: radio
Very very easy....unscrew one black screw on the right side of the center dash panel (the little hook in the right middle). Then pull steadily on the panel, it WILL pop out. Just make sure you don't yank your cig lighter wire out. If you've downloaded the FSM, it'll show you a pic of it. I did it recently to install the RAH code mp3 cd player.
Old Jun 15, 2006 | 08:00 PM
helrod's Avatar
helrod
Default RE: radio
SORRY I'M A LITTLE IGNORANT. WHAT'S THE FSM AND WHAT SITE IS IT ON ?
Old Jun 15, 2006 | 08:50 PM
Ramsport_03's Avatar
Ramsport_03
Default RE: radio
its held on by clips, just pop them off, BUT its a major pain in the *** to do it
Old Jun 15, 2006 | 09:40 PM
jrsick's Avatar
jrsick
Default RE: radio
FSM is the service manual and you can download it for free at http://www.hemitruckclub.com . The best way I've found to remove the dash panel is to take off the glove box (easy, no tools req'd) then start pulling on that corner of the center dash trim (after you've removed the screw behind the bag holder hook. When you disconnect the antenna from the back of the radio be sure to pull on the black plastic sleeve and not the metal part of the antenna cable.
Old Jun 16, 2006 | 12:42 PM
helrod's Avatar
helrod
Default RE: radio
GOT IT .... THANKS
Old Jun 16, 2006 | 10:38 PM
HemiLonestar
Default RE: radio
Don't hafta take the glove box off...hell, don't even need to open it. It took me all of 5 min to swap head units.
