Burn In
Old Jul 7, 2006 | 01:27 AM
Dodge Leaks's Avatar
Dodge Leaks
Default Burn In
I've got no sympathy for street racers, but if you want to go to a track that sounds like fun. My 06 1500 does all I want and I can scoot up the on-ramp or pass with authority; but I do have a question for you racing types.
When you do a burn-in you're holding the brakes and applying throttle at the same time, does that mean the rear wheels are not only working against the road friction but also the rear brakes? How hard is this on the transmission?
I could never bring myself to do this to good tires, but I might slip over to the dark side next time I'm due for tires.
GJ
Old Jul 7, 2006 | 01:33 AM
stump_breaker's Avatar
stump_breaker
Default RE: Burn In
we called it powerbraking or powerjacking. It's not good on the tranny or rearend for that matter - like pulling a heavy load - but once you start spinning, you let up on the brakes and just apply light pressure to control the truck/car. Some people actually loosen the brakes (drum style) or install a type of kill switch so pressure does not go to the back but those are hardcore show-offs that do that.....
Old Jul 7, 2006 | 01:37 PM
Nicky B's Avatar
Nicky B
Default RE: Burn In
What you do is completely stop your truck when in drive just let the car roll and touch the brake just enough to stop your truck then ram the throttle. I do it every now and then just for like 2seconds to leave 5foot black lines.
Old Jul 7, 2006 | 03:08 PM
motorhead426's Avatar
motorhead426
Default RE: Burn In
Also called a "Brake-Torque" for us in Michigan.
Old Jul 7, 2006 | 03:50 PM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: Burn In
ORIGINAL: stump_breaker
Line locks.
Old Jul 7, 2006 | 03:51 PM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: Burn In
ORIGINAL: motorhead426
I am 10 minutes south of MI, never heard that before.
Old Jul 7, 2006 | 05:20 PM
Drew's Avatar
Drew
Default RE: Burn In
3rd gear, spin the engine to 2500 and dump the clutch, God I love boosted launches in 3rd[sm=gears.gif]
Old Jul 7, 2006 | 06:43 PM
magnethead's Avatar
magnethead
Default RE: Burn In
ORIGINAL: Nicky B
Thats what i do in my 1 ton. Granted i have 20 year old rear drums on it so it's not like i have rear brakes anyways. And yes it's bad for the driveline.
Old Jul 7, 2006 | 08:04 PM
nos4fuel's Avatar
nos4fuel
Default RE: Burn In
if ur drivng an 06 then goodluck burning out, DC softened everything to make sure that this type of thing doesnt happen. I think that the only way to override this would be with the Superchips remote when it comes out, no word on when that will be.
Old Jul 7, 2006 | 10:24 PM
onlyone's Avatar
onlyone
Default RE: Burn In
I have about 700 miles on my 06 RC SB Hemi 2WD. I have yet to PB it. But if I smack the throttle from a dead stop it will chirp the tires and pin you in the seat. I much prefer that instead of roasting 20 inch tires. Im sure it would have no problem roasting those 20's if I wanted it to. When I had my 01 Dak R/t it had no traction whatsoever. This new Ram is amazing and would spank my old R/T.
