Underdrive pulley
Old Jul 9, 2006 | 11:33 PM
bandit96's Avatar
bandit96
Default Underdrive pulley
OK guys i need some help here, i installed the motoblue pulley and now when i turn on the blower and turn the wheel it makes a god awful sound. (belt noise) that is the only time it makes a noise. what shoud i do???
Old Jul 10, 2006 | 01:48 AM
g352nv's Avatar
g352nv
Default RE: Underdrive pulley
Tighten the belt.
Old Jul 10, 2006 | 02:35 AM
eatsleepdrivesc's Avatar
eatsleepdrivesc
im not familiar with that pulley but we do have belt tensioners on our rams that should keep the belt tight enough to not strain the bearings...
Old Jul 10, 2006 | 10:33 AM
motorhead426's Avatar
motorhead426
I can assume you put on the shorter belt....right? If your having that problem with a new pulley and new belt (of the correct length) then that worries me, because I got my pulley a couple of weeks ago and have not had the chance to install it yet.
Old Jul 10, 2006 | 02:09 PM
collisiondaddy's Avatar
collisiondaddy
is the motoblue pulley the same as the ASP because i've never heard of motoblue but on the website they have the same dyno sheet and the pulley looks exactly the same
Old Jul 10, 2006 | 02:10 PM
AIR RAM's Avatar
AIR RAM
ORIGINAL: collisiondaddy
Yes they are the SAME thing.
SPEED SAFE, AIR RAM
Old Jul 10, 2006 | 02:22 PM
collisiondaddy
thank you air ram
Old Jul 11, 2006 | 11:19 PM
bandit96's Avatar
bandit96
It is the Motoblue pulley, and yes i did install the correct belt with it. It runs fine but when i turn on the air or the blower and i turn the wheel its loud as hell!!!!
Old Jul 11, 2006 | 11:31 PM
motorhead426
I was just looking at my pulley, (See my other post) and saw that the pulley I got is for a 6 groove belt. Is yours also a 6 groove pulley? This could be an issue, since the stock pullies on the Hemi are 7 groove. The one less groove could very well not be enough surface area for the torque on the pullies. Just my $.02
Old Jul 11, 2006 | 11:51 PM
bandit96's Avatar
bandit96
mine is 6 groove belt. it should not matter, alot of people on here have them. so i dont know!!
