Evaporative Emission Control System Purge Control Valve Circuit Shorted?
Old Jul 22, 2006 | 06:18 PM
20brewcity02's Avatar
20brewcity02
Default Evaporative Emission Control System Purge Control Valve Circuit Shorted?
P0445. okay, so i searched and found no definate answer. exactly what does this code mean? and how do i fix it?
Old Jul 22, 2006 | 09:44 PM
Gone Fishin's Avatar
Gone Fishin
Default RE: Evaporative Emission Control System Purge Control Valve Circuit Shorted?
It means that the evaporative system vacuum solenoid isn't firing. I had the exact same problem with mine recently. I took it in under warranty and they said they found a wire near the front drive shaft was rubbing. They cut 10" out and soldered in a new chunk. Then they wire tied back into the frame rail.
The solenoid is energized to pull a vacuum on your tank and charchol canister.
Old Jul 23, 2006 | 06:58 AM
20brewcity02
sadly being as i bought mine used as an 02, i dont have a warranty. where is the solinoid so i can try to track down any problems like that
Old Jul 23, 2006 | 09:49 AM
Gone Fishin
I believe its located with the charchol canister which is located near the frame rail behind the driver.
Old Jul 23, 2006 | 04:14 PM
20brewcity02
awesome, thanks
