NEED ANSWER PLEASE HELP
Old Jul 23, 2006 | 01:21 AM
NYDODGE's Avatar
NYDODGE
Default NEED ANSWER PLEASE HELP
I HAVE A 06 HEMI WITH AIRRAID INTAKE SUPERCHIP AND MAGNAFLOW EXHAUST,MAYBE SOME ONE ON HERE HAS ENCOUNTER THIS PROBLEM (WHEN IAM CRUSING AT 60 OR FASTER AND I SLOWLY APPLY PRESSURE TO THE GAS PEDAL TO SPEED UP THE TRUCK BOGS OUT UNTILL I STEP ON IT HARDER BASCIALY IT FEELS LIKE WHEN YOU HAVE A SIX SPEED TRANS AND PUT IT INTO SITH AT 30 MPH AND GIVE IT GAS THERE IS NOTHING THERE SAME PROBLEM PLEASE HELP I EVEN PUT THE SUPER CHIP PROGRAM BACK TO STOCK AND SAME PROBLEM I THINK IT STARTED AFTER I ADDED THE COLD AIR INTAKE SYSTEM BUT NOT SURE OH YEAH ONE MORE THING WHEN I AM IN 91 PERFORMANCE MODE AND AC IS ON AT ILDLE OR IN PARK THE IDLE GOES UP AND DOWN FOR A FEW SECONDS PLEASE HELP THANKS
Old Jul 23, 2006 | 10:28 AM
RedSS454's Avatar
RedSS454
Default RE: NEED ANSWER PLEASE HELP
I don't know what to tell ya about the idle problem, but I have the same problem on my almost stock 04. Only performance mod is the flowmaster muffler. If I'm cruising and give it teh gas, it will pick up but not drastically. I need to press the gas harder for the trans to downshift to get the gear right to accelerate. Is it an actual bog where it noses over, or just you press the gas and nothing happens? The premis is teh same as with a stick in 6th and giving it the gas, just that it takes a second for the trans to kick down.
Chris
Old Jul 23, 2006 | 10:35 AM
kenihemi's Avatar
kenihemi
You are in OD with the converter locked up at 60mph. Unless you get it to downshift, it will bog. They all do that.
The idle going up and down a little when the ac is on may be caused by the pcm. When the compressor comes on, it raises the idle a little to compensate for the lost hp.
On some vehichles, that is really noticeable.
Old Jul 23, 2006 | 09:12 PM
HazArD22083's Avatar
HazArD22083
nope...its because the 06s have the mds.. it keeps it in fifth but kicks out 4 cylinders. so running on 4 at 60 in 5th gear will do it....saves gas. step on it and it punches the four other cylinders into use... happens only when your cruising for a little bit at that particular speeds
[IMG]local://upfiles/38598/B4D8A480D01F482E9D939B679DC58FB1.jpg[/IMG]
Old Jul 23, 2006 | 11:23 PM
onlyone's Avatar
onlyone
Mine has the same bog at about 2500-2800 rpm's. usually does it in 2-3rd gear. I will wait untill my first free oil change to have them look at it.
