keyway lift
Old Jul 27, 2006 | 09:05 PM
Max00racer's Avatar
Max00racer
Default keyway lift
I just got a keyway leveling kit in the mail that I bought off ebay. My uncle has an auto body shop and not even he will go near the torsion bars. Says I should goto a truck repair place. Does anybody know how much that will run me?
Old Jul 27, 2006 | 11:14 PM
redram5.9's Avatar
redram5.9
Default RE: keyway lift
Save yourself the time and $ and tighten your torsion bolts, then return the keys. Same results, less time, $, and headache.
Old Jul 28, 2006 | 01:50 AM
Max00racer's Avatar
Max00racer
how do u do it the right way? Lift the truck up, then tighten it same on the other side and then just get an alignment?
Old Jul 28, 2006 | 03:28 AM
redram5.9's Avatar
redram5.9
Don't need to lift the truck up. Can be done with the truck on the ground. Measure current height first, tighten bolts 3-4 turns, apply pressure to front end to unload torsion bars, re-measure and tighten bolts to desired height (do not increase front end height by more than 2.5"). Can be done in 10-15 minutes then have a alignment done.
Old Jul 29, 2006 | 03:48 AM
Max00racer's Avatar
Max00racer
will 2.5 inches level it?? and by putting pressure on the front end...do I just sit on the hood or something?
Old Jul 29, 2006 | 04:54 AM
Monkeyman's Avatar
Monkeyman
Jack up the front end first. Then crank the T bars. Let it back down and try to bounce the front end a few times to help settle it. Then drive it straight to an alignment shop. Some have stated that they needed new, longer shocks while others have said that the stock shocks are OK. Dunno for sure about that.
Old Jul 29, 2006 | 02:32 PM
redram5.9's Avatar
redram5.9
Can also be done on the ground. 2.5" will get you close to level, maybe and inch difference or so.
redram5.9's Avatar
redram5.9
