Ram 04 promblem whit trans
Old Jul 29, 2006 | 04:12 PM
hola's Avatar
hola
Default Ram 04 promblem whit trans
hello these is my frist post i hope to make it fine
i was driving on the street and just like that the car dief, then i turn it on, and when i try to move the car i put it on drive but nothing happend, on revers and the same frist 2 3 gear but i never see nothing the car dosent like he whant to move, i all ready check the oil and the oil panel to see if i have metal but everything was fine, the code is p-0700 but i see and that is just transmission control module.
i was traing to see wat happend i left the car like 40 min running but i not shure but i think sow the oil dosent get warm from the transmission
can some one can tell me more,
Old Jul 29, 2006 | 04:54 PM
silentblinder9502's Avatar
silentblinder9502
Default RE: Ram 04 promblem whit trans
HUH?
Old Jul 29, 2006 | 06:51 PM
Palm's Avatar
Palm
hola,
According to the trouble code that you say it is producing, and the description of the trouble that you say you have, the problem seems to be in your electronic transmission control module. The transmission functions in your vehicle are electronically controlled and this is the module in your transmission that performs shifting and other functions within the unit. If this module is defective, or inoperative for whatever reason, your transmission will not operate. Unfortunately this is not a user-replaceable item, at least by the average user. I suggest that you take your vehicle to a good transmission repair shop for repairs to this module in order to restore function to your transmission.
Old Jul 29, 2006 | 10:13 PM
Gone Fishin's Avatar
Gone Fishin
HOLA,
You might try one thing before you run it in to a shop. Before you do what is below, write down the P code that popped up on the odometer.
First--Disconnect the battery at the negative post.
Second--turn the headlights on for 5 minutes, this ensures that all the computer modules have erased their memory
Third, turn headlamps off, then reconnect the negative post on the battery.
This is a complete method of rebooting all the computer modules in the truck.
Start it up and see if the trans will engage. If so, take it for a drive around the block, making sure it hits all the gears, including reverse. If any of the gears don't shift right, get it into a shop before any damage is done to the mechanicals inside the tranny. If you are the first or second owner, with the warranty transferred, it may fall under warranty work at the dealer----make sure you check first, so you don't end up with an outragous bill
Good Luck
