Camber Bolts
Old Aug 15, 2006 | 09:25 PM
Kevno6's Avatar
Kevno6
Default Camber Bolts
I leveled my truck last week and brought it in for alignment, they had to order camber bolts for me. Has anyone else had to do this also. Thank You
Old Aug 15, 2006 | 09:36 PM
DieselDemon's Avatar
DieselDemon
Default RE: Camber Bolts
I'm not real familiar with 3rd generation, but do you need caster alignment pins? The two bolts that fit thru the lower control arms? The also have an eccentric cam (looks like the shape of an egg) welded at one end. The other end fits on after you slide it thru the bushing. I could be wrong. My 95 has no camber adjustment unless you change ball joints. If it is caster pins you need, make sure that the place doing the ordering knows what degree of max seperation you need. There are several specs. For instance, my Ram only needs 2.2 degrees of seperation or "travel". Again, I am not real familiar with the 3rd gens.
Good luck.
