leveling kit for 03' ram 1500
Old Aug 16, 2006 | 10:54 PM
jsub's Avatar
jsub
Default leveling kit for 03' ram 1500
i have a 03' ram 1500 2WD laramie and need help getting the right size leveling kit for it. should i get a 1", 1.5", or 2"? does anyone know which leveling kit i should get? thanks
Old Aug 17, 2006 | 12:08 AM
kvsmith2004's Avatar
kvsmith2004
Default RE: leveling kit for 03' ram 1500
I would say get the 2", the 1" really is not much. With the 2" it will look more level. What kit are you looking at getting? A coil spacer or new coils?
Old Aug 17, 2006 | 12:54 AM
jsub's Avatar
jsub
i was thinking about getting the coil spacers. got any suggestions on which ones work best?
Old Aug 17, 2006 | 01:12 AM
wmichell227's Avatar
wmichell227
Does the 2WD have front coils? I have an 03 4WD and had to adjust the torsion bars
Old Aug 17, 2006 | 01:20 AM
jsub's Avatar
jsub
im not sure...everywhere ive looked they sell the coil spacers for the 2wd models
Old Aug 17, 2006 | 01:49 AM
prerunner's Avatar
prerunner
i went 2" in the front, and i'm still about a 1/4" lower in the front than the back! But thats on an 06.
Old Aug 17, 2006 | 01:54 AM
kvsmith2004
The 2wd have coils, the 4wd have torsion bars. I have heard good things about daystar, I have a 2.5" Coil spacer sitting in the garage right now just waiting to be put in. Shop around you should be able to get a set for under $100, I got mine for $70 I think from 4wheelparts.
Old Aug 17, 2006 | 02:03 AM
jsub's Avatar
jsub
are they pretty simple to install?
Old Aug 17, 2006 | 02:10 AM
kvsmith2004
That I am not sure, I have read alot of diffrent things about install. From that I understand you will need a coil compressor and some special took to take the ball joints off. Oh and the shock has to come out. I am trying to see if it is possible to compress the coil enough to just put the spacer on top with out taking anything else off but I don't think ill be that lucky. From what I have read it only takes about an hour to 2 hours when you know what you are doing and if you have the right tools.
Old Aug 17, 2006 | 02:11 AM
kvsmith2004
Take a look at this https://dodgeforum.com/m_266515/tm.htm
