Bigger tires?
Old Sep 4, 2006 | 07:44 PM
dirtydodge02's Avatar
dirtydodge02
Default Bigger tires?
Anyone know just how big of tires one can stuff under a 3rd gen ram at the stock ride height? Or with just a leveler? Appriciate any help on this one guys. Thanks!
Old Sep 4, 2006 | 08:40 PM
AIR RAM's Avatar
AIR RAM
Default RE: Bigger tires?
I have 305 50 20's on my 02 with a 2-4 Hotchkis suspension drop. I dont think I could go much larger than that as I do have SLIGHT rubbing on the sway bar and rear inside fender skirt. Nothing that will cause any problems or to get worried over but It is rubbing.
SPEED SAFE, AIR RAM
Old Sep 4, 2006 | 10:54 PM
onlyone's Avatar
onlyone
33's
Old Sep 4, 2006 | 11:06 PM
woken's Avatar
woken
With a front end leveler, you should be able to fit 35s with over an inch to spare in front of and behind the tire. There's plenty of room in the rear wells. Just watch your width with larger tires as they will clear the fenders and throw stones.
Old Sep 4, 2006 | 11:17 PM
dirtydodge02
Thanks guys. I'll have to go get the leveler put in and check fit a few things, but the input helps alot.
Old Sep 5, 2006 | 01:58 AM
HemiBuell's Avatar
HemiBuell
35's
Old Sep 5, 2006 | 01:14 PM
melloyello2198's Avatar
melloyello2198
I just went thru this last month.
If you keep everything stock, you can fit 33s, watch your width. If you tweak the torsion bar susp. you can fit 35's, or if you add the leveler kit you can do 35's. I chose to get rid of my 20's and use 17s with 33x12.50 tires, looks great, and rides great.
Old Sep 5, 2006 | 02:38 PM
prerunner's Avatar
prerunner
If you go 35's with a 2" leveling kit....make sure to get the proper rim for it. I had 35's on with 17x10's -25mm. They had some rubbage with the bottom plastic on the front bumper.
Old Sep 5, 2006 | 05:22 PM
hoppyram06's Avatar
hoppyram06
cool, what would be the proper wheel backspacing and offest to fit a 34 or 35" tire, (keeping width to about 12" on the tire)?
Old Sep 5, 2006 | 08:23 PM
prerunner's Avatar
prerunner
i have no clue. i would ask that question in the tire section. i ended up going with 18x8.5.... i forgot the offset.....and a smaller tire.
