Would like to level truck
Old Sep 12, 2006 | 06:32 PM
billfish's Avatar
billfish
Default Would like to level truck
I have a 2003 Dodge Ram 1500 Quad Cab that is 2 wheel drive. I am looking to level front. Any suggestions?
Old Sep 12, 2006 | 06:54 PM
1baddodge's Avatar
1baddodge
Default RE: Would like to level truck
If your looking to level your truck by what your saying about leveling the front you must be wanting to raise the front since in 2wd trucks the *** end is higher than the front. I have two suggestions 1. You could buy some coil spacers that will raise your front end. 2. If you want to give a look of a lifted truck get a 4wd. Just a suggestion. I hope this helps let us know how it goes for you.
[IMG]local://upfiles/41359/E4975D8CF1BF40FBBB4DE33664BC23EF.jpg[/IMG]
Old Sep 12, 2006 | 10:05 PM
prerunner's Avatar
prerunner
http://www.performanceproducts4truck...on+Lift+System
Keep in mind that you'll have to replace the shocks as well. I used the Revtek leveling system, but they don't show anything for a 2wd application. You can call them.
And the 2wd and 4wd's come with the front lower than the back. The 4wd is just a bit higher.
