Speed Sensor Wire
Old Oct 2, 2006 | 03:07 AM
jackdan's Avatar
jackdan
Default Speed Sensor Wire
Does any one know where the speed sensor wire is on an 06 Dodge Ram 2500? Perferably a location in the cabin. I am installing a navigation unit and need to get this hooked up. Looks like there is a connection under the hood, but i'd prefer not to make any holes in the firewall.
thanks
Old Oct 6, 2006 | 02:11 AM
1baddodge's Avatar
1baddodge
Default RE: Speed Sensor Wire
First off what kind of nav system are you running? REason being is i am running the Pioneer AVIC-N2 and have not come across that issue at all. If you are running an older model maybe then. Let me know.
[IMG]local://upfiles/41359/7245FD9FD2CD47DE894054F7298BEC7F.jpg[/IMG]
Old Oct 9, 2006 | 02:17 AM
1baddodge's Avatar
1baddodge
By the way if your still wondering which wire is your speed sensor here it is. It is on your top plug on the computer the wire is dark green with a yellow strip pin # 13 I hope this helps.
[IMG]local://upfiles/41359/B758079DB7244C7ABAD3D25751666666.jpg[/IMG]
