3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
The part # is 16701 and it is for the 2wd 1500 2006 Hemi, it cost $535 with free shipping. I installed it myself and it was a pain to get the stock first muffler off, i had to heat it with a torch, to install was very easy. as far as the power goes when i installed it i had disconnected the negative battery cable as per the instructions to reset the computer. For the first couple of days if i floored it from a complete stop i would smoke the tires until i let up on the gas, now the computer relearned everything it will not do that anymore. as far as sound it sounds real good, the only thing is you can hear everything especially if you have the cruise control on, you can hear it engine break when you are going down hill. as far as when the mds kicks in you really cant tell it just sound like a lower rumble.
Antrock, I installed a cat exhaust system on my truck, should i disconnect the battery. It did not tell me to in the instructions. I thought about that but i figured the computer will learn.
i got them from autotrucktoys.com, they are the putco covers they are not solid replacements. as far as price i do not remember just check out their website.
