Headers
Old Oct 12, 2006 | 04:24 PM
GreyHemi's Avatar
GreyHemi
Default Headers
On average how long does it take to put on headers on a hemi?
Old Oct 12, 2006 | 04:38 PM
410 hp hemi's Avatar
410 hp hemi
Default RE: Headers
If you know what you are doing, about 2-2.5 hours. I had to take the front tires off to get to the manifold, that is the easiest way>
Old Oct 12, 2006 | 06:07 PM
GreyHemi's Avatar
GreyHemi
Default RE: Headers
Did you have to take the starter off.... The gibson instructions say to take it off.
Old Oct 12, 2006 | 06:37 PM
helopilot's Avatar
helopilot
Default RE: Headers
NO
Old Oct 12, 2006 | 06:53 PM
turbot_bird's Avatar
turbot_bird
Default RE: Headers
my mom is wanting me to put headers on her hemi.
Old Oct 12, 2006 | 11:15 PM
reiderr's Avatar
reiderr
Default RE: Headers
When I did my Gibson headers, I jacked up the front end with a floor jack under the front cross member. Took off the front wheels. Then removed the fender liners. Then each side of the engine is fully exposed. From there I supported the exhaust pipes with a jack stand underneath each pipe where it bends under the frame from the cat converters.
Taking off the existing exhaust manifods is easy. Putting on the headers was hard because the bolts are hardly accessible with anything other than a small wrench. Once on, be prepared to retighten all the header bolts frequently. They loosen up quickly particular in the first few hundred miles.
Ultimately, I couldn't keep up with the retightening regime every oil change, developed a gasket leak, and then just put the old cast iron manifolds back on. Never had another leak, never needed to retighten the bolts, and didn't observe any change in gas mileage. Of course I have a light foot and never did any WOT acceleration measurements where the headers might have made a difference. I now have the headers sitting in a box in my gargage taking up space...
Roger...
Old Oct 12, 2006 | 11:27 PM
HemiBuell's Avatar
HemiBuell
Default RE: Headers
Locking header bolts work great. I have never had a problem with a set of headers using them.
Old Oct 13, 2006 | 01:13 AM
deanj287's Avatar
deanj287
Default RE: Headers
You want those headers off your hands?!
Old Oct 13, 2006 | 11:12 AM
motorhead426's Avatar
motorhead426
Default RE: Headers
ORIGINAL: reiderr
Roger...
Why would anyone go the trouble of spending the money, and taking the time to install headers if your never going to do any WOT accels? When I put headers on anything, you can garuntee that I plan to drive it like I stole it, hahaha.
Old Oct 13, 2006 | 11:37 AM
YeahItsAHemi345's Avatar
YeahItsAHemi345
Default RE: Headers
ORIGINAL: reiderr
Roger...
[sm=boink3.gif]Turn those dusty headers into green paper...
