Tranny Hiccup? or worse
Old Oct 13, 2006 | 01:05 AM
gyerxa's Avatar
gyerxa
Default Tranny Hiccup? or worse
All,
Long time reader first time poster new member kinda dude.
I have been having some hitches in my ride in the last few days. Cruising at about 70-80 with the cruise control engaged and everything else normal. No load or anything wierd and normal winds ie 10-15kts from any particular direction. I have a 40 mile commute every day on I-84 and recently I can feel what can best be described as a hiccup in my drive train as often as a dozen or so times during each ride. Its not overly excessive but it is noticeable and its no the road.
It feels as if the Tranny is for a split second kicking down a gear but it happens so fast the Tach doesn't move and my speed doesn't change. Almost like I hit a bump. I also experience it when the cruise control is not engaged.
I have so far checked the tranny fluid both cold and hot and everything seems normal. No other modifications have been made to the truck and it has low miles ~39000. At 33k I had the tranny filter fluid changed and flushed with nothing reported back to me from the dealer when they did it. I am current on all maintenance and would not consider myself a hard driver.
Any ideas on trouble shooting? I am probably going to leave it at a dealer but I am anticipating I will have to drive around with a tech until it happens and I can explain it to them real time.
Troubled,
Out!
Old Oct 13, 2006 | 02:46 AM
crashedcdo's Avatar
crashedcdo
Default RE: Tranny Hiccup? or worse
i had similar problem with my s-10 blazer. but it turned out to be my ingnition coil going bad. heater hose was leaking water on top of the coil. would miss every once and a while. felt like the tranny slipping. fixed the water leak but still had the same problem and finally the coil crapped out. OEM coil was $80, and an MSD was $55. go figure.
Old Oct 28, 2006 | 07:59 PM
gyerxa's Avatar
gyerxa
Problem solved.
Got WAY worse on a particularly windy day going up a slight incline.
The previous week I had them do a Tune up at the Dealer. They miswired the second sparkplug wires to cyclinders #3 and #5. I was quite pissed.
Anyways runs great now. Thanks for the info.
