Fog lights not working.....
Old Oct 18, 2006 | 11:56 PM
spinfreak's Avatar
spinfreak
Default Fog lights not working.....
My fogs lights stopped working. I had the jumper installed for probably a year now so they stay on with the high beams, if that matters. Anyway, I checked the fuse under the hood and it was good. The relay was very hot (so hot that you couldn't hold it for more than a econd or two), so I thought it might be bad. I swapped out another relay (same size, etc), and they still won't work. I tried it with the jumper to the high beams in place, and without it. Doesn't work either way.
Any ideas what it might be? Are there any other fuses than those under the hood? Thanks in advance
Old Oct 19, 2006 | 02:02 AM
cbrewer954's Avatar
cbrewer954
Default RE: Fog lights not working.....
I'm not trying to sound like an ***, but did ya check the bulbs? You didn't mention it in your post.
Old Oct 19, 2006 | 09:46 AM
spinfreak's Avatar
spinfreak
LOL.....yes, I did check them
Old Oct 19, 2006 | 08:34 PM
Gone Fishin's Avatar
Gone Fishin
Take the relay box apart and make sure you didn't melt off the connection wire the relay sends power to.
Old Oct 20, 2006 | 10:49 PM
spinfreak's Avatar
spinfreak
Damn.....I really don't want to tear apart the fuse box. I was hoping that someone else might have had a similar experience and could offer me the solution. If not, then I guess I'll be tearing stuff apart.[:@]
Old Oct 23, 2006 | 10:29 PM
spinfreak's Avatar
spinfreak
BTT for the weekday crowd
