HELP what does code P 0442 mean?
Old Oct 23, 2006 | 08:06 PM
hdvespa's Avatar
hdvespa
Default HELP what does code P 0442 mean?
Driving home from work my check engine light decidied to come on. I checked the code using the key on/off trick and comes up with a P 0442. Any clue what that error code means and possible problems/ fixes.
Old Oct 23, 2006 | 08:26 PM
silverram99's Avatar
silverram99
Default RE: HELP what does code P 0442 mean?
It is a small evap system leak. Make sure your gas cap is tight, if it is replace it. The cap could be bad causing that code to set. If neither of those fixes it, you will be looking at alot of dollars spent searching for a leak in the EVAP system.
Old Oct 24, 2006 | 02:36 AM
eds2003ram's Avatar
eds2003ram
sometimes you can get that code if you leave the gas cap lose after a fill up and run the engine with it loose. If you can get a superchip pak or hipertech unit, to read the code directly , it will give you the option to delete the code from the ecu. Just think back to see if you may have not tighten the cap all the way. I did it and got the same code, erased it the next day and never got it again. Hope this is also your problem. Good luck.
Old Oct 24, 2006 | 10:56 AM
hdvespa's Avatar
hdvespa
Thanks for the input guys. I put gas in the truck 250 miles before it happenned. I cleared the code and removed/ re tightened the gas cap. I will see what happens next.
Old Oct 25, 2006 | 05:40 PM
TEF's Avatar
TEF
If it comes on again get underneath the truck and check the formed rubber hoses going in to the charcoal box (right in front of the gas tank) That's what made mine come on...
Old Oct 25, 2006 | 06:02 PM
hdvespa's Avatar
hdvespa
TEF, Was the hose cracked? Did you have to get a new one from the dealer or was it just loose?
Old Oct 25, 2006 | 06:10 PM
20brewcity02's Avatar
20brewcity02
mine was cracked, i just wrapped the whole thing in electrical tape til im able to get to the dodge dealer again (its a about an hour away).
Old Nov 3, 2006 | 08:35 PM
TEF's Avatar
TEF
sorry it took me so long to reply. I've been on dirt bike forums lately....Yeah.. It was cracked. I got really stiff heater hose and clamps to replace it. Works great....
Old Nov 3, 2006 | 11:14 PM
raz123's Avatar
raz123
i just fixed that code on my truck 2002 dodge ram 1500 2wd 4.7 v8
i opened up the old gas cap inside 1 piece of metal was rusted rotten
Old Dec 15, 2007 | 12:41 PM
ruffnready5's Avatar
ruffnready5
I got that code and was told evap. Raise the hood and change the fuse for your AC fan....problem solved
