Towing
Old Oct 24, 2006 | 03:13 PM
rickdilleshaw's Avatar
rickdilleshaw
Default Towing
have a 2004 Ram 1500 Quad with Hemi. I need to drive 850 mile to tow an 1978 chevy 1/2 ton PU back to Houston, TX. So, can my trans take that abuse?
Old Oct 24, 2006 | 03:35 PM
moparmike's Avatar
moparmike
Default RE: Towing
Shouldn't be a problem, just use the tow haul mode. I tow a 8500lbs trailer with my 1/2 ton hemi and so far so good. Good luck
Moparmike
Old Oct 24, 2006 | 11:16 PM
HemiLonestar's Avatar
HemiLonestar
Default RE: Towing
No problem just when you're in the hill country (or any time you're not on level ground) turn the overdrive off.
Old Oct 25, 2006 | 12:37 AM
reindeerman's Avatar
reindeerman
Default RE: Towing
For the distance of 850 miles I would put the “Chevy” on a properly equipped trailer. Make sure your truck has the correct class hitch and is trailer brake equipped.
As far as the tow/haul mode, keep it in that mode all of the time with the O/D off when towing. That’s what it’s made for!
