amp install in qd cab
Old Nov 6, 2006 | 02:04 AM
GOD RAM IT's Avatar
GOD RAM IT
Default amp install in qd cab
IM going to install the amp myself and Im using a converter so I can use my amp with my stock HU.
where did you all tie into your rear speaker wires? I was going to tie into the rear speakers by the door but I cant get to them. I might have to pull the molding between the two doors?
also, how did you guys run your wires to keep them hidden.
My amp and dual 12" box are under the rear seat.
thanks
Bill
Old Nov 6, 2006 | 07:05 PM
GOD RAM IT's Avatar
GOD RAM IT
Default RE: amp install in qd cab
ttt
Old Nov 7, 2006 | 01:30 AM
eds2003ram's Avatar
eds2003ram
tapped into the drivers side kicker panel. the speaker wires run along side the back of the panel. At the moment I don't know the color of the wires but if you have the electic schamatic manual it will show you the exact harness. since the front seats were removed , to place my amp, I was able to run the wires under the carpet with no problems.
Old Nov 7, 2006 | 02:35 AM
GOD RAM IT's Avatar
GOD RAM IT
are both the right and left speaker wires on the same side?
Old Nov 7, 2006 | 12:40 PM
Denniss66's Avatar
Denniss66
i just took the center piece of my dash out and left the little converter thing in behind the dash. it was just three screws to take out. then i ran the wires behind the carpet i pulled off all the plastic that goes to the back ran it under there then ran it right under the back seat the wires are well hidden until you lift the back seat because i never hid the wires under there i dont even have my amp bolted down i would like to get a box that fits underneath the back of the seat. for 2 10s but i think i should pay my truck off before i start goin big with the stereo.
