911 HELP
Old Nov 7, 2006 | 01:58 AM
tpowell3499's Avatar
tpowell3499
Default 911 HELP
Just spent my last dime on wheels so now I hear that the stock 275 tires will not fit onto a 10" wide wheel. Anybody know if it will or not?/ THANKS
Old Nov 7, 2006 | 10:23 PM
Stroker's Avatar
Stroker
Default RE: 911 HELP
I don't know why they wouldn't fit they just won't look or ride the same and it is posibble if it spreades the sidewall out too far to damage the wheel if you hit a pot hole kinda like running low pros. You need to check with Michellin ? and see what their recomended wheel size is. If they have a good chart it will give you a range you will be safe with.
Old Nov 8, 2006 | 03:41 PM
Jetpig's Avatar
Jetpig
They will fit just fine as long as they are not too tall to rub in the fender well. Stock 20's are a 9 inch rim with 275's. Not to worry!.
