slot and drilled or just slotted
Old Nov 7, 2006 | 02:17 AM
eds2003ram's Avatar
eds2003ram
Default slot and drilled or just slotted
hey guys ,just need some advice on how to go. Was thinking of upgrading my rotors to Power slot rotors but was also thinking of getting the drilled and slotted ones to dissapated more heat. I had the slotted and drilled with EBC break pads on my sports car and they kicked but. Don't know how they will work on a 5k lbs truck ,so need some I input.
Old Nov 7, 2006 | 04:10 AM
JRH_PowerWagon_06's Avatar
JRH_PowerWagon_06
Default RE: slot and drilled or just slotted
If it's just normal street use, drilled are ok. I have seen slotted rotors that cracked at a hole. They were all on vehicles that saw hard track use though. I've heard that Slotted (or even plain) ones can crack too, but I have never seen it.
If you do any heavy, long down-hill braking with a load or trailer, I would stay away from cross-drilled.
I have slotted only on my Cobra. Slotting is for keeping the pads "fresh" and venting super-hot boundary layer gasses from the surfaces. Not really a cooling device. I would recommend them. Pads will wear quicker, but that's why it works.
I have used cross-drilled only rotors before, they work good. I would not use the ones that look like they are excessively drilled. You need surface area.
Same thing goes for slotted rotors. The slots shouldn't be wide. Don't need to be.
Old Nov 7, 2006 | 10:30 AM
motorhead426's Avatar
motorhead426
I've done a lot of brake jobs, and been happy wth the stock rotors in the past on many different types of vehicles. I've also heard a lot of different opinions on drilled and slotted rotors. Just taking those facts in mind, I don't see myself using the drilled or slotted rotors on any of my vehicles. FYI, as "JRH_PowerWagon_06I" said I do not recommend them for high speed use. Many guys (including the Lemans Porsche Race Team) remove them if they come on the cars from the factory, because they do not hold up to abuse very well. Long story short... Its solid/vented rotors for me.
Old Nov 7, 2006 | 01:53 PM
Mystro's Avatar
Mystro
I had Powerslot rotors on my last Ram and they sucked. I had to send them back and the company was not easy to work with at all.
I replaced them with some good Wagner rotors and pads.
Old Nov 7, 2006 | 07:13 PM
stump_breaker's Avatar
stump_breaker
Solid rotors with Ceramic pads. If you just have to be fancy, don't do drilled.
