Spark Plugs in 4.7L
Old Nov 9, 2006 | 09:39 PM
BgBluRam's Avatar
BgBluRam
Default Spark Plugs in 4.7L
Whats up guys and gals, I have a question:
Is changing the spark plugs on our 4.7L engines a do-it-yourselfer? I have almost 65k on the truck, and I havent changed them yet, am thinking it is about time.. Is there a lot to it? I am an experienced Ford mechanic, (I know.. but now I drive a dodge) and have a ton of experience with 4.6L fords, and of course the all popular 5.0 engines, but haven't done much accept exhaust work and intake to my new dodge... Anyone have any pointers? Which plugs should I use? Should I get new plug wires as well? Thanks in advance, sorry I'm such a newb when it comes to the Mopar stuff..
Old Nov 9, 2006 | 09:46 PM
NYPANAMA42's Avatar
NYPANAMA42
Default RE: Spark Plugs in 4.7L
Welcome from the dark side BgBluRam, glad to see you've finally seen the light. I have the same engine, but had a dealership change mine. Maybe one of the others will provide you with the info you're looking for.
Old Nov 9, 2006 | 10:10 PM
mrchip04's Avatar
mrchip04
its completely do it yourself it wasnt hard. the spark plugs enter through the top of the cylinder not the side. if you look at your intake manifold you'll see eight plastic tube looking things with wires connected, it just unscrew the bolt that holds those down and they pull right off. then they change like normal. the spark gap is set at .040
Old Nov 9, 2006 | 10:22 PM
Denniss66's Avatar
Denniss66
is that the same idea for the 5.7l hemi.
Old Nov 10, 2006 | 12:10 AM
BgBluRam's Avatar
BgBluRam
ORIGINAL: mrchip04
Thank you so much. I know better than to come on here and ask a question without even poping the hood to look for myself. Are there any specific plugs that I should use? I would like to use the best, any help would be appreciated! Thanks!
Old Nov 10, 2006 | 12:26 AM
Mattes_4.7's Avatar
Mattes_4.7
I have the 4.7 in my truck and my JGC. I just changed the plugs in my JGC. I took my time and it took me about 1.5 hours. Mainly cause I was messing with my little girls at the same time. I used the Bosch Platinum, they come pregapped so you don't have to do anything to them. Just pull the coil pack off, pull out the old plug, use some anit sieze, install the new plug, install the coil pack, and your done. The Bosch have been running great in my JGC. I'm sure they will do the same for the Ram. Good luck.
Old Nov 10, 2006 | 09:51 PM
BgBluRam's Avatar
BgBluRam
Any specific plug to use?? Was thinking either Bosch or Autolite...
Old Nov 11, 2006 | 12:20 AM
hemiyellow's Avatar
hemiyellow
DC Insider
yah, i've always used Bosch plugs in my other rams they seem to run just fine...not much to doin plugs on the 4.7, got take off the 10mm nut holding down the coil packs and then they just pull right off, it can easily be done in under 45 min, just my $.02 worth
Old Nov 11, 2006 | 01:48 AM
BgBluRam's Avatar
BgBluRam
OK cool, that's what I'll do then.. My truck has 65k on it, does that sound like enough mileage to need to change the plugs? I used to change the plugs in my Mustang GT about every 30k..
Old Nov 11, 2006 | 02:40 AM
hemiyellow's Avatar
hemiyellow
DC Insider
yah, the 4.7 plugs need to be changed every 30K
