View Poll Results: A poll
alpine type Rs in front type Ss in back all powered under amp
72.22%
alpine type Rs in front powered by amp. type Ss in back with out amp
22.22%
alpine Type Rs in Front with amp no back speakers
5.56%
Voters: 18. You may not vote on this poll
speaker and amp set up?
Old Nov 19, 2006 | 06:45 PM
brianas's Avatar
brianas
Default RE: speaker and amp set up?
I would recommend a set of 6 1\2 or 3\4 component set for your front
run off an amp -as stated-- run your rears right off the headunit
an adapter plate is readily available or can easily be fabricated to
fit these in the factory location.
also recommend checking these out
http://www.pioneerelectronics.com/pn...263623,00.html
if $$ is not an issue these are among the best out there
g/l
Old Nov 19, 2006 | 07:35 PM
powerjunkie's Avatar
powerjunkie
cant i just turn the power down to the rear speakers from the sup? wouldnt that sound good?
Old Nov 19, 2006 | 08:00 PM
powerjunkie
okay how bout a pair of 6 1/2 type R components powered with a f-250 amp and type Ss 5 1/4 in the back with no amp power. hows that? o and where would u mount the tweeters in the truck?
Old Nov 19, 2006 | 08:36 PM
allmine's Avatar
allmine
I wouldnt even bother amping the speakers...i dont think they are gonna blow lol...unless you listen to them on full blast...i dont, speakers are designed to be listened to at about 75% of the max volumne..and the subs will pick up all your bass needs.
6x9's in the front, 6.5's in the back. just buy the speakers with the built in tweeters.
Old Nov 19, 2006 | 08:47 PM
ImAti0n's Avatar
ImAti0n
Where you guys all putting your sub and boxes at? I have a QC and still looking for the right place.
Old Nov 19, 2006 | 09:00 PM
allmine's Avatar
allmine
I built a box to put on the floor in the middle by the cupholders in the back, didnt wokr out well sounded to shiity as the sub was just pounding into open air so i threw it up against the seat now it sounds fine, but, ill be needing a new box as my box was an angled one...so ill need a square one and ill just buckle it in in the middle of my back seat...no big deal to me, i can take it out if im taking 3 passengers back there...as you wouldnt be blasting the sub with a full load of ppl, not i atleast.
You can buy ones off ebay for under the back seat, but im in Canada and i dont want to pay for the massive shipping.
http://cgi.ebay.ca/DUAL-12-DODGE-TRU...QQcmdZViewItem
Old Nov 20, 2006 | 12:18 PM
truckin151's Avatar
truckin151
Dont power the fronts unless they require an amp to run than what your sterio will be putting out. And remeber just because they say (just as a refference) 300 Watt Max doesn't mean you have to have 300Watts pushing them at all times. Personally I'd go with the Amp powering the backs and leave the fronts alone specially if you are going to have any subs back there. Then again it also depends on the type of music you listen to and if you enjot the sound of the base or if you want to hear more of the music than the base.
Old Nov 20, 2006 | 08:00 PM
FR3AK27's Avatar
FR3AK27
Do you need a certain type of wire harness for 06's? Stopped by best buy today and the guy came back saying he could order one but it would cost $125 bucks[:-] Ive installed stereos in all my other vehicles and the most a wire harness ran me was $15 bucks. So if there is a certain type of harness i need for an 06 dodge ram1500 could someone point me in the right direction? Thanks alot.
Old Nov 20, 2006 | 09:45 PM
allmine's Avatar
allmine
a wire harness for my stereo cost me 10 bucks at wal-mart, and another 10 bucks for an antenna adaptor...of course the wire harnass i bought wasnt connect properally and i had to re-wire one of the wires...go figure works now though
Old Nov 20, 2006 | 09:58 PM
brianas's Avatar
brianas
yes this is correct
you need the can-bus adapter to properly install any equipment
average price for these is about $100.- retail stores are always
gouging-- so 125 is about right.
good news about this though-
all the wiring you would need for an aftermarket NAV
system will be provided by this adapter--greatly simplifying the install
generally you want your better quality speakers for your front stage
and also want more power for your front stage--these are the speakers
you should hear when listening to your music etc...
rear speakers = rear fill \ for rear passengers
g/l
