'06 PCM Reset
Old Nov 20, 2006 | 09:12 PM
New2Durango's Avatar
New2Durango
Default '06 PCM Reset
How do you reset the PCM on an '06? i just installed my CAI and want to do the PCM? Thanks.
Old Nov 20, 2006 | 10:23 PM
mazz's Avatar
mazz
Default RE: '06 PCM Reset
Disconnect the negative cable from the battery. Wait about twenty minutes or so. Hook it back up. Works for me.
Old Nov 20, 2006 | 10:24 PM
damquick1's Avatar
damquick1
What brand CAI did you install?
Old Nov 21, 2006 | 12:00 AM
New2Durango
No brand that I know of:
http://cgi.ebay.com/ebaymotors/03-04...spagenameZWDVW
Old Nov 21, 2006 | 01:52 AM
bevans's Avatar
bevans
Taken from KenHemi on Dodge Talk
Disconnecting the batter will not reset the pcm.
You need to leave the battery connected, remove the pcm fuse then buckle the driver seat belt, put the key in and turn to start and hold it there (it won't start). You will hear a chime and if you hold it a lttle longer you'll hear a 2nd chime.
The first chime is the pcm is reset. The second is the trans control is reset.
Disconnecting the battery will reset some stuff, but not the pcm stuff that you are looking for.
Old Nov 21, 2006 | 01:55 AM
damquick1's Avatar
damquick1
Is it the same procedure for the 4.7?
Old Nov 21, 2006 | 01:10 PM
kenihemi's Avatar
kenihemi
Thanks bevans,
It should work for the 4.7. Try it and see if you get the chimes, if you do, I suspect it worked.
Old Nov 21, 2006 | 11:10 PM
GIRam's Avatar
GIRam
Do you need to reset the PCM or will it learn the new intakes air flow. there in no mass air sensor . I believe it is just a intake pressure sensor. The computer should adjust the air/fuel curves. Yes/no comments?
Old Nov 22, 2006 | 11:49 AM
79LRT's Avatar
79LRT
KeniHemi, I did this on my Ram. THanks . I was wondering if the procedure is the same for an 05 Neon?
Old Nov 22, 2006 | 12:26 PM
kenihemi's Avatar
kenihemi
Don't know if it works on other pcms, but its worth a try.
You don't NEED to reset the pcm for a CAI, the pcm will adjust. But it will adjust quicker with a reset.
