06' Ram 1500 4x4 leveling kit
Old Dec 8, 2006 | 12:07 PM
volzgo's Avatar
volzgo
Default 06' Ram 1500 4x4 leveling kit
I just bought an 06' Ram 1500 quad cab 4x4. I have already ordered the 2" spacers for my front struts so I can level it out and put bigger tires on it. I want to keep my stock aluminum wheels(17x8). Does anyone know what size is the biggest tire that I can put on without doing any more modifications? Please keep in mind that my wheels are only 8" wide. Thanks.
Old Dec 8, 2006 | 12:14 PM
TXST8tj's Avatar
TXST8tj
Default RE: 06' Ram 1500 4x4 leveling kit
33x12.50s will fit perfectly. 35x12.50s would probably fit but be a tight squeeze. it's ideal to run a 12.50 tire on an 8' wheel. any wider (10") and you don't get the same flotation and your sidewalls are more prone to damage, along with the outer rim of the wheel. anything wider than a 12.50" tire, i'd swap over to a 10" wide wheel.
Old Dec 8, 2006 | 02:25 PM
genesis's Avatar
genesis
Does the '02 have the same front end as '06?
I am trying to find out if anyone makes a leveling kit for my truck.
Old Dec 8, 2006 | 05:18 PM
edreeve75's Avatar
edreeve75
volzgo , were did you find the 2in spacer for a 1500 I have a 04 4x4 1500 and could not find anything but a 4.5" lift any help would be gret
Old Dec 8, 2006 | 10:56 PM
rory71's Avatar
rory71
The spacers don't work on 02-05 1500's, they use torsion bars. The 06 models have a strut assembly like a coil over shock. I put 2-1/2" spacers on mine, sits perfectly level.
Old Dec 9, 2006 | 01:57 AM
bradwcc's Avatar
bradwcc
If you use the spacer kit be careful using a 35x12.50 tire. I bought a set of nitto mud grapplers in that size and they would not work. An A/T tire should work with some minor trimming on the plastic.
Old Dec 9, 2006 | 06:26 AM
diehardpolice's Avatar
diehardpolice
hey bradwcc, how do you like those mud grapplers?? How do they ride on the street and perform in the mud?
Old Dec 11, 2006 | 11:03 PM
derwood's Avatar
derwood
How are you making out with the spacers? What size and make of tire did you go with? By the way, where did you get your spacers?
Old Dec 11, 2006 | 11:12 PM
Phatboy's Avatar
Phatboy
I just got the new 4Wheel Parts catalog, and ORA magazine and they have a 2" leveling kit, with shocks for less than 200.00, now it is the new torsion keys, with 2 pro-comp shocks. I think they are pro-comps.
I would check them out, If I dont trade mine 05 in on a mega cab I might have to invest in the 2" kit, a magnaflow and a CAI. A new head unit and some nicer speakers....LOL.
<Edit> www.4wheelparts.com </Edit>
Old Jan 19, 2007 | 01:08 PM
volzgo's Avatar
volzgo
sorry it took so long to reply, but i forgot where i bought them from until i just found my receipt. i got them from truckexpressions.com but i don't think they will work on yor truck.
