Where is diff fluid filler?
This is a really stupid question, and I just have not had a chance to take a good look, but where is the filler hole/plug for the front rear and rear rear? I have the 9.25, (i think), with 3.92 gears and LSD. Thanks.
I took a quick look about a month ago, but I couldnt find it, am I just blind?? On all my jeeps, it is right on the diff cover, and I have worked on trucks that have it on the other side of the diff, above where the driveshaft comes in, didnt see it there either....
The filler hole is covered by a rubber plug that you pry off with a flat-blade screwdriver. It's located on the back of the diff in the 3 o'clock position locking from the rear. On the cover that comes off when you drain the fluid. There's nothing like a threaded plug found on the engine oil pan.
Roger...
Roger...
