Install writeup: 2wd coil spacer leveling kit
Old Feb 12, 2011 | 02:35 PM
  #51
bigdaddyII's Avatar
bigdaddyII
Going back to the original post, I was under the impression that the stock spring isolator was not to be replaced. I thought the leveling kit became the new spring isolator. If that is true, it may be the reason the OP actually ended up with a 3" lift instead of the 2" the kit advertised. Someone correct me if I am wrong please. I have one waiting on me at my local UPS pick up office (out of state, my dad is terminally ill and on his deathbed), and install as soon as I get back home. I just want to do it right.
Old Feb 12, 2011 | 05:31 PM
  #52
Matt99's Avatar
Matt99
Sorry to hear about your dad
Generally we don't replace the isolators. Some people with 1-1.5" spacers stack them and might wrap themwith bailing wire. I don't like the idea of keeping it, but it is an inch tall so you would get more lift
Old Mar 5, 2011 | 05:05 PM
  #53
dodge7's Avatar
dodge7
is it safe to stack the stock isolater on top or is it just goin to be problems
Old Mar 5, 2011 | 05:39 PM
  #54
Matt99's Avatar
Matt99
Depending on the new spacer height but if you are greedy and have to stack em put a few wraps of bailing wire around them
Old Mar 7, 2011 | 12:39 AM
  #55
dodge7's Avatar
dodge7
I found a 3 inch leveling kit so will it actually lift my truck 3 inches
Old Mar 7, 2011 | 11:20 AM
  #56
Matt99's Avatar
Matt99
Post a link and your model
Old Mar 7, 2011 | 12:30 PM
  #57
weedahoe's Avatar
weedahoe
Hall of Fame Member
^^ Yep, really need to know your trucks info. You should put it in your profile also
Old Mar 8, 2011 | 08:44 PM
  #58
dodge7's Avatar
dodge7
http://cgi.ebay.com/ebaymotors/ws/eB...TM:MOTORS:1123
Sorry guys will update profile andi know this is 3rd gen rams but I have an 09 2wd these are the spacers I found
Old Mar 9, 2011 | 02:29 PM
  #59
weedahoe's Avatar
weedahoe
Hall of Fame Member
I dont see why those would not work. Just make sure you get an alignment afterwards.
Old Jun 21, 2011 | 12:24 PM
  #60
MONONC420's Avatar
MONONC420
I have an 07 1500, and I have a 1.5in leveling kit, and im wondering what shocks I need. I see that the OP used Procomp ES3000, but it seems there are multiple part numbers for them. Is this the one I need?
http://www.amazon.com/Pro-Comp-32654...2007&carId=001
