What does this code mean?
Old Dec 22, 2006 | 04:30 PM
Malu's Avatar
Malu
Default What does this code mean?
What does the code P0441 mean. The enginge light on my '03 is on and the key trick shows this code.
Old Dec 22, 2006 | 06:23 PM
1baddodge's Avatar
1baddodge
Default RE: What does this code mean?
That code means Evaporitive Emission Control System Inncorrect Purge Flow, I hope this helps. Let us know.
[IMG]local://upfiles/41359/EBD4B70124944F14819D104B74FDB7AB.jpg[/IMG]
[IMG]local://upfiles/41359/FBAE5A4CB74F4032832054CE1AD5996A.jpg[/IMG]
Old Dec 22, 2006 | 11:02 PM
Malu's Avatar
Malu
Ok. Thanks alot, I think. Is this something that can be fixed at home or should I give in and take it to the dealer?
Old Dec 23, 2006 | 01:13 PM
CarGuyOhio's Avatar
CarGuyOhio
I could be wrong but I think that has to do with the gas cap or the vent tube on the gas tank.
If you have a aftermarket gas cap (maybe you bought a locking cap or yours was stolen so you bought one at a local parts store), in any case if you have a aftermarket go to the dealership and get a OEM on. There have been reports of some aftermarket caps not working correctly. If you do this clear your code.
Old Dec 24, 2006 | 05:59 AM
Malu's Avatar
Malu
I appreciate the feedback guys. I have a stock gas cap so I don't think that's the problem. I was talking to another Dodge owner and he mentioned that it could be an oxygen sensor. Could this be the problem? Where is this located?
Old Dec 24, 2006 | 11:34 AM
Dodge Tech's Avatar
Dodge Tech
here are the possable probs for that code
nvld switch operation., evap purge sol,evap purge sol vac supply. NO O2 the O2 does not have anything to do with this code the evap system is used to purge HC out of the Gas tank and use it for burning and speed density calucations on your gas mileage.
Look for a vac line broken to the Solenoid, Much over that u will haft to take it to the dealer and have them run the NVLD force Test
unless u like spending money on a crap shoot and replacing parts untill u get the one that might be bad.
Old Dec 24, 2006 | 02:57 PM
Malu's Avatar
Malu
Thanks alot guys looks like a trip to the dealer is in my near future. Happy Holidays to all.
Old Dec 27, 2006 | 10:03 PM
cg's Avatar
cg
I had the same code. I replaced the gas cap, fixed the problem.
