front drive shaft grease and disenguagement
Old Dec 25, 2006 | 04:57 PM
tommu56's Avatar
tommu56
Default front drive shaft grease and disenguagement
RAM 2500 ctd auto 4x4megacab
I looked in manual but couldent find answer.
I tried to grease front driveshaft and couldent find grease fitting inthe doubleuniversal joint.
I tried to turn shaft over (in 2wd) its lock up.
Had my wife pull truck forward and backward to find fitting still mia.
1, Can any one explane were fitting is?
2. Dosent drive shaft disengauge (sp) from wheels?
Old Dec 25, 2006 | 05:46 PM
Gone Fishin's Avatar
Gone Fishin
Default RE: front drive shaft grease and disenguagement
There is a grease zerk there. You will need a needle to access it. You will also need to lift the front wheels to rotate the drive line. It is located on the transfer case side of the joint. Make sure you bring a flashlight-----you will definitely need it. Of all the maint I perform on my truck, greasing that zirk is a major PAIN-IN-THE-***!!!!!
Unfortunately, D/M decided to go with the full time run of the front drive train---when you lock in and unlock, you are only disengaging the drive train at the transfer case. The front axles do not unlock.
The fitting kinda sits at an angle in the cross, and looks like a bright spot with a dark dot in it. I know this sounds kinda lame---but only way better to describe it is with a picture. One of the guys did do this a long time ago here on the forum. If I can find it I will re-post for you, but I suggest doing a search too----Good Luck!!!
Old Dec 25, 2006 | 08:04 PM
tommu56's Avatar
tommu56
Thanks I did find the other post after I posted does any one know if they make manual hubs for the front end?
tommu56
Old Dec 27, 2006 | 08:12 AM
JRH_PowerWagon_06's Avatar
JRH_PowerWagon_06
The fitting is in the centering ball of the double-cardan joint.
when you grease it, you don't get any grease in the actual cross of the joints. Those are non-greaseable, just like the others on the rear shaft and the very front u-joint.
