Multiple Displacment System
Old Dec 26, 2006 | 01:37 AM
SlickHemi06's Avatar
SlickHemi06
Default Multiple Displacment System
Does anyone in here have any clue how to disable the MDS system. Tell me exactly how its done.
Old Dec 26, 2006 | 01:42 AM
whitmard's Avatar
whitmard
Default RE: Multiple Displacment System
keep your foot on the gas. why would you want to disable a gas saving device?
Old Dec 26, 2006 | 04:09 AM
BigAJ's Avatar
BigAJ
Some say push the Tow/Haul button, but I find this kicks it out of overdrive as well and it revs to high.
Don't worry about it. You can't even tell when it's working.....
Old Dec 26, 2006 | 05:15 PM
rotested's Avatar
rotested
I have heard both from different people, some say the Tow/Haul prevents it from kicking in and some say that OD off prevents it from kicking in. So try both and see what works.Also, I remember reading on here somewhere that if you do the 6.1 cam swap,you would alsohave to swap in 6.1 valves and 6.1 valve springs which as a side effect, prevents the MDS from functioning as it is with those parts that the MDS works.So, you may be able tokeep your stock cam and swap in the valves and valve springs out of a non MDS Hemi? Check outsome "6.1 cam swap" threads for more info. Hell, if it was me and I was going to go that far to disable the MDS, I would do the 6.1 cam swap and get 25 more horses!
Old Dec 26, 2006 | 05:30 PM
Silver Eagle's Avatar
Silver Eagle
I thought it only works with cruise control.
Old Dec 26, 2006 | 05:38 PM
BigAJ's Avatar
BigAJ
MDS is a big Chrysler secret...
I am sure it's not that great. Probably rarely comes on... it's hard to get the advertises milage without MDS nevermind with.
Would be nice to know when it's on so you can regulate your driving habits.. but I think it would drive me nuts to see a little "MDS" light go on and off all the time on the dash.
Just forget that it's there and drive.............that's what they designed it for.
Old Dec 26, 2006 | 09:54 PM
SlickHemi06
Well in order for my 6.1 cam swap to be sucessful i have to disable it...
Old Dec 27, 2006 | 02:27 AM
06HEMIon24s's Avatar
06HEMIon24s
i would like to know how to turn it off to cause it sounds awful when you have an exhaust and it shuts down to 4
Old Feb 22, 2007 | 12:53 PM
verhoffracing's Avatar
verhoffracing
Junior Member
I have heard of a gains of20 to 35 horse gain but what kind of torque gains do you get, extra horseys don't get you much in a 5500lb truck
Old Feb 22, 2007 | 02:27 PM
DelawareDon's Avatar
DelawareDon
Under "normal" driving conditions, MDS is operational about 40% of the time. And it's true....for most people with a louder exhaust, the sound of MDS when it goes from 8 to 4 cylinders is not a good thing. Some have described it as sounding like the "fop-fop-fop-fop" that helicopter blades make. The shop who has done custom exhaust systems for me for over 10 years refused to build one for my '07...saying that every single one he had done for Ram owners with MDS had come back with the request to restore the exhaust system to stock.
