Shock Problem
Old Jan 6, 2007 | 02:56 AM
ramtastic's Avatar
ramtastic
Default Shock Problem
Hello from a first time poster. I just bought a 03 4x4 1500 laramie this past weekend. The first thing I did was check out this forum for leveling information (a very popular topic). I read in multiple places that I needed Bilstein B46-2129 shocks, so I went to Summit and purchased a pair of BSN-F4B462129HO's. I attemped to install them on my unlifted truck tonight. One went on (barely), and one bottomed out before I could get the lower bolt installed. The extended length of the new shocks is over 6 inches longer than stock. I know they will both go on after I crank the torsion bars, but I don't think there is any way they will not bottom out the first time I hit a bump. What did I do wrong?
Any help would be appreciated.
Thanks,
Jason
P.S. - if anyone in the Cedar Rapids , IA area is looking for a 1994 f150 4x4 with 291,000 miles so you don't have to get that shiny Ram dirty in poor weather let me know.
Old Jan 6, 2007 | 11:56 AM
big guy's Avatar
big guy
Default RE: Shock Problem
My first thought is you must have the wrong shocks. So I googled up shocks. Went to Shockwarehouse.com.For an 03, 4x4 they list Be5-6928-H0 for front and Be5-2550-H1for the Rear. I then went to summit site and punched your part # Bsn-F4B462129h0. It came up listed for a Ram 3500 1994 to 2002.So it looks like you have the wrong shocks.
Old Jan 6, 2007 | 12:26 PM
big guy's Avatar
big guy
I just went back to summit to do double check?I was wondering?Your shock bsn-f4b4622129h0 is listed for a 1500 as well.
1500- 1994 to 2001,
2500-1994 to 2002,
3500-1994 to 2002,
Any ways just to clarify, I didn't want to post the wrong info.
Old Jan 7, 2007 | 01:58 AM
ramtastic's Avatar
ramtastic
Thanks Big Guy.....I've read that I do need these older style shocks if I'm leveling my truck. I know a lot of you guys have done this. What am I missing? Are the additional letters before and after the B46-2129 causing me problems?
Thanks,
Jason
[IMG]local://upfiles/52439/3F8C35B87578420199B2905A96F1D102.jpg[/IMG]
[IMG]local://upfiles/52439/95551EDD78434ECE90667D9C45F56E6F.jpg[/IMG]
Old Jan 7, 2007 | 02:28 AM
HemiBuell's Avatar
HemiBuell
BSN-F4B462129HO
That is the exact part number taken from my Summit invoice.
They fit my truck fine after turning the bars.
Old Jan 7, 2007 | 03:01 AM
ramtastic's Avatar
ramtastic
Was the difference between your shock lengths as large as what you see in the pic above? It seems to me that if I can't even put them on at stock height I'd be very close to bottoming out with it raised 2". Maybe I'll just try it.
Jason
Old Jan 9, 2007 | 12:25 AM
HemiBuell's Avatar
HemiBuell
They looked massive before I put them in and when I took the stock ones out they looked way too small. They work, that's all I know for sure.
I think the truck handles a bit tighter with them and the bars turned, which I feel is an improvement.
