Bfgoodrich All Terrains on 20's...
Old Jan 20, 2007 | 05:17 PM
crazyimport's Avatar
crazyimport
Default Bfgoodrich All Terrains on 20's...
Is anyone on here running the Bfgoodrich All Terrains on the stock Ram 20's?
I beleive i saw a guy running them at work on his truck. But i went into the store to get a quote and he was telling me nothing will fit it properly in this model of tire?
Any suggestions. Thanks
Old Jan 20, 2007 | 06:35 PM
djr04's Avatar
djr04
Default RE: Bfgoodrich All Terrains on 20's...
BFgoodrich makes a T/A KO all terrain tire for 20" rims. It's not available in 275/60R20, but they do have a 285/55?R20. You would just need to have your pcm updated with your new tire size to be sure your speedo was correct. The T/A KO gets great reviews from what I've seen. You can find more info on them at tirerack.com
Old Jan 20, 2007 | 07:32 PM
gyerxa's Avatar
gyerxa
If you're looking for decent and cheap AT's for the stock 20"s I went with Cooper Discoverer 275/60R20's. $900ish for four installed. at Commercial Tire
Old Jan 21, 2007 | 01:34 AM
CarGuyOhio's Avatar
CarGuyOhio
They are sweet looking tires! Had them on a Ranger I use to own. Gripped very good in wet weather as well. As for dry traction under power, will it was a Ranger with a 4.0, I have no idea.....
Old Jan 23, 2007 | 09:05 PM
snake2083's Avatar
snake2083
You can run 285 55R 20's with out any problem as they are just barely smaller than the stock tires. If you want to go up a size you could look at 285 65R 20's like I have. I'm running astock 4x4 QC and the tires don't rub at all. Check out this forum for some pics.
https://dodgeforum.com/m_667487/tm.htm
Just be prepared to write a BIG check. Mine ran about $1600 with road hazard and alignment. Hope this helps.
