removing glue from debadging
Old Jan 31, 2007 | 08:43 PM
Horseapples's Avatar
Horseapples
Default RE: removing glue from debadging
no holes,just glue,If you want to debadge,warm the letters with a heat gun then slide a piece of mono filiment fishing line behind the letters. It does a good job!
Old Jan 31, 2007 | 08:46 PM
Horseapples
the easiest way is to go to the dealer and get new ones Dilly,they come adheasive backed just set a straight line using achalk line and a level,then peel and stick!
Old Jan 31, 2007 | 09:41 PM
chopperzen's Avatar
chopperzen
don't use a level.. You could find some on eBay. If they are intact and not bent, pull off the old adhesive and go to an AutoZone or someplace and buy some 3M moulding tape. It's black. An easy way to "level" em up is to run tape off of a highlight. Like on the crease of the door or off of your moulding. Don't measure down from the window or up from the bottom of the door. The measurements change.. I wrap dozens of vehicles and have to take em off all the time.
Old Jan 31, 2007 | 11:23 PM
dillyw's Avatar
dillyw
thanx guys, 3M tape sound good will give that a shot first , thnks again.
Old Feb 1, 2007 | 02:54 PM
BigAJ's Avatar
BigAJ
"STICKER OFF"
http://www.hardlineproducts.com/stickeroff.html
