alternator being weak?
Old Feb 12, 2007 | 12:13 AM
austin's Avatar
austin
Default alternator being weak?
Well apparently my alternator is too weak to run my accecories. I can see my volt meter drop rapidly when the sub hits really hard, and at night all the lights drop for an instant... It is fine to run all day with, but I think I am going to need a stronger alternator. Anybody else done this already?
Old Feb 12, 2007 | 12:38 AM
Foiled's Avatar
Foiled
Default RE: alternator being weak?
Most people that install a high demand audio system replace the battery with one that is designed to handle the load or they add a 2nd one. You can also add capacitors to help with the hard draw.
Old Feb 12, 2007 | 05:01 PM
osteodoc08's Avatar
osteodoc08
Go get yourself an AGM (Absorbed Glass Mat) battery like an Optima Red Top/Yellow Top and a capacitor rated for your amp and all the problems will be solved. The stock alternator puts out 130Amps, IIRC.
Old Feb 15, 2007 | 08:14 PM
FFMedic1479's Avatar
FFMedic1479
I use a cap for all of my amp... a must if you don't like dimming lights.
Old Feb 15, 2007 | 08:20 PM
stump_breaker's Avatar
stump_breaker
Yeah, you need a cap and to upgrade the charging and ground wires from the alternator. I always went no smaller than 2ga.
Old Feb 15, 2007 | 11:58 PM
usnfirefighter's Avatar
usnfirefighter
If your bass is dimming your lights, you may want to look into a capacitor for your amp. I personally haven't used one, but I heard from a reliable source that they are worth it.
