2nd - 3rd shift problem with SC
Old Feb 18, 2007 | 05:11 PM
Caduceus72's Avatar
Caduceus72
Default 2nd - 3rd shift problem with SC
During hard acceleration (WOT) the engine rpms bounce back and forth at the 2-3 shift and finally kicks in to 3rd gear.
2006 Dodge Ram Hemi 1500 QC
Superchips 91 Perf Tune
Rev Limit 6150
1-2 shift 5900
2-3 shift 5900
Are my shift points too close to the rev limit and that is why the truck revs back ad forth from shift to shift?
Old Feb 19, 2007 | 01:27 AM
FFMedic1479's Avatar
FFMedic1479
Default RE: 2nd - 3rd shift problem with SC
I am assuming that you have the Flashpaq for the hemi. Try differant settings for the WOT shift points... if you go to the Superchips forum,you are not the only person with these issues. Most of the answers go to "every vehicle is differant and has differant temperments". I want to say 6150 is some recommended shift point for both the 1-2 and 2-3 shift point.
Old Feb 22, 2007 | 02:47 AM
paul bunyan's Avatar
paul bunyan
my guess is that you are hitting the rev limiter. Try lowering your 2-3 shift point 50 rpm and raising your rev limit 50rpm and check it out.
