Door Seal
Old Feb 27, 2007 | 04:02 PM
FFMedic1479's Avatar
FFMedic1479
Default Door Seal
On my driver side door, the door seal is getting all torn up by the door itself. The tear is occuring right at the "A" pillar, basically catuching on the last upward angle of the door. Anyone else with this issue? It isn't leaking, but it is going in to get replaced. It almost appears the door could have been hung wrong, but the rest of the door seems to be equally gapped all the way around. Thanks.
Old Feb 27, 2007 | 08:02 PM
stump_breaker's Avatar
stump_breaker
Default RE: Door Seal
I'm not surprised to hear it's tearing. These Dodge door seals are some of the goofiest I've ever seen. I get a ton of wind noise - not from driving, it's actually pretty quiet, but from driving and then the wind blowing into the side of the truck. Depending on which side of the truck the wind hits, it sounds like a loud roar. They suck....
Old Feb 28, 2007 | 12:15 AM
Hellbilly1's Avatar
Hellbilly1
mine is the same way i get snow packed in my drivers side door i thought at frist it was my windshield not sealed but its the door
Old Feb 28, 2007 | 12:44 AM
CarGuyOhio's Avatar
CarGuyOhio
They will replace them, it is a TSB. There is a new design that will prevent it from happening again.
Old Feb 28, 2007 | 10:24 AM
eds2003ram's Avatar
eds2003ram
Take it to the stearlership , Had mine replaced with two new and improved ones for $0.
Old Feb 28, 2007 | 03:46 PM
FFMedic1479
Sweet... thanks. And I like the price.
Old Feb 28, 2007 | 09:45 PM
65Catalina's Avatar
65Catalina
My seal sucks too, at 50 mph+ it sounds like the door isnt closed all the way. so its just the seal?? and its an 02' so i dont have the warrenty anymore, so should i replace it myself? or go professional?
Old Mar 1, 2007 | 04:48 PM
T Man's Avatar
T Man
ORIGINAL: 94rt10ohio
Would you know where I could find a copy of the service bulletin? I get that same noise and my dealer tells me they have never heard of a bulletin for this.
Old Mar 11, 2007 | 12:23 AM
QUADCABHEMI's Avatar
QUADCABHEMI
They cover them under your 3/36. Im just out of that but they are like $20 each side which isn't too bad.
Old Mar 11, 2007 | 01:11 PM
helopilot's Avatar
helopilot
ORIGINAL: T Man
http://dodgeram.info/tsb/2005/23-049-05.htm
http://dodgeram.info/tsb/2005/23-005-05.htm
