Have any of you guys tried this?
Sounds pretty good, I just like to know if anyone here has purchased these.....
http://cgi.ebay.com/ebaymotors/2006-...QQcmdZViewItem
Thanks,
-Eli
Thanks,
-Eli
For $600 you can have any upholstery shop do the same job with much less wrinkling. Call some shops in your area but around southeast michigan that is about the going rate for TIGHT leather seats.
In the taupe colored area they are made to be a pleated (wrinkly) leather. If you see any other wrinkling then it's probably due to the fact that they had been on all of 10 minutes and it was 20 degrees outside. Now that they have been out in the sun there is not a wrinkle to be found.
Quote:
ORIGINAL: helopilot
Thanks for the feedback, did you install them yourself? Or did you take them in to get installed...? The auction recommends a professional shop, just looking for your input, I think they look nice..ORIGINAL: helopilot
-Eli
I installed them myself, here is a how-to
http://www.dodgetalk.com/forums/showthread.php?t=135291
replace the stars with "dodge talk" no spaces
Quote:
ORIGINAL: helopilot
I'm not a registered user so I can't see anything... ORIGINAL: helopilot
I was just figuring if you did that yourself then I can imagine what my interior shop could do for me..... Not to say it's not good looking but when the shop does it they use glue, they even add foam where it's needed etc. etc.
I think this kit could look great in mine... I'll think about it....
Thanks for the feedback!
-Eli
