i just got a dodge 4.7
Old Mar 22, 2007 | 01:17 AM
dswan414's Avatar
dswan414
Default RE: i just got a dodge 4.7
Oh, hmm, they mine must have 3.55's becuz it has the 4.7L V8. It's def a low one, that's all I know for sure, it cruises about 1650 RPM @ 60 mph in OD.
Old Mar 22, 2007 | 01:19 AM
BgBluRam's Avatar
BgBluRam
OOPS!: After researching a bit more, the 3.21's are now made available in the short bed 4.7L's now, but I don't know if they were an option in 03-04 like our trucks. I have a 03 4.7 and it had 3.55's.. Sorry to doubt you I'll shut up now!
Old Mar 22, 2007 | 01:30 AM
dswan414's Avatar
dswan414
No, I'm pretty sure you are more knowledgable about 3rd gen Ram's than I am, I'm pretty new to them. I've only had mine since Christmas. I love everything about it except that I don't have a 4x4 model and no limited slip or lock dif. To me, it seems very important to have that (standard) on a full-size truck, with its lightweight rear-end and especially 2WD models that could use the traction. 2WD's that don't have a dif lock are 1WD's in my book (for off-road practicality and purpose).
Old Mar 22, 2007 | 01:40 AM
BgBluRam's Avatar
BgBluRam
Believe me I know what you mean! I drove around for almost 2 years before adding the Auburn posi unit, and I wheeled it with the open diff, it was not pretty. A locking diff should definately be standard equipment on a full size, I don't know why it isn't, but hopefully before they do make it standard, they will come out with a factory system that doesn't fail. (referring to the c-clip problem)
Old Mar 22, 2007 | 01:44 AM
dswan414's Avatar
dswan414
I haven't heard about the c-clip problem, plz tell me about it if you don't mind.
(BTW, thanks for feeding me all this info, I appreciate it)
Old Mar 22, 2007 | 01:51 AM
BgBluRam's Avatar
BgBluRam
Well the trucks that do come from factory with the DCX 9.25" Anti-spin diff (Yours is also the DCX 9.25" diff., just open) have been having extensive problems with their C-clips failing. This C-clip is coming loose and falling into the gears which is scarring the gears and causing heavy damage. I have heard of a lot of the guys actually getting the entire rear end swapped out under warranty because the shards of metal are getting down into the axel housings and scarring the axels as well.
Of course you don't have to worry about this problem if you have an open diff. because you don't have the c-clips.
Old Mar 22, 2007 | 02:01 AM
dswan414's Avatar
dswan414
Well I guess it's actually a better thing that I don't have the optional anti-spin eh. And all this time I was complaining lol. Do the 4x4's have the same dif and problem?
Old Mar 23, 2007 | 12:46 AM
BgBluRam's Avatar
BgBluRam
ORIGINAL: dswan414
As far as I know yes, because the anti-spin diff is the same I believe.
Old Mar 23, 2007 | 12:51 AM
damquick1's Avatar
damquick1
ORIGINAL: RGVplayer07
i just got a dodge 4.7 reg cab and i just wanted to know what does it run stock and what do i need on it to make it run 14's
thanx
You need a HEMI.......
Old Mar 23, 2007 | 12:54 AM
HighDuke1911's Avatar
HighDuke1911
ORIGINAL: damquick1
thanx
that was exactly what i was about to say too. lol.
