start up oil burning 06 ram hemi
is it alot? i think ive noticed mine blow a little smoke when i first crank it up, but i just figured that it was because it was cold outside. ive never notice it being blue, its always been white on mine
I would stop by your dealer and lodge a compliant about it NOW.
More than likely it just needs a little more breaking in at 5500 miles, but, if it does continue to smoke after 10k miles, YOU got a problem that needs to be addressed.
I'm guessing valve guide seals, as Dodge runs then loose. That is where the HEMI tick comes from. Yours may be too loose--but it also a little soon to tell--IMO
It only smokes a little a startup and only after the truck has sat for awhile (8-10 hours). It never smokes anytime the engine has already warmed up. The only change I have made lately is that I filled my gas tank with premium gas instead of the usual mid-grade brand.
With 5500 miles, it's break-in is done. I've heard of Diesel engines giving better mileage after extended miles,butdoubt a gas engine is going to see better oil control after this many miles.
This smoke issue is what I would expect from a vehicle that was owned by someone who believes modern engines don't need a break-in period, or unfortunately was abused by test drivers before the vehicle was sold.
ORIGINAL: tailgatedrinkin
your not supposed to run 91 or higher in these trucks, only 89octane
What???? is that really the case, If so I am glad you made that post. I have been running 87 in mine and was gonna give it some higher octane on the next fill-up
Trending Topics
