Fuel Filter
Old Mar 27, 2007 | 10:21 PM
jslaymon's Avatar
jslaymon
Default Fuel Filter
I have an 03 Ram SLT w/5.7 I just purchased recently. Went to change the fuel filter and couldn't locate it. Owners manual left me to believe it doesn't have one. What's the scoop?
Old Mar 27, 2007 | 10:26 PM
hemiyellow's Avatar
hemiyellow
DC Insider
Default RE: Fuel Filter
the fuel filtersare located at the bottom(1) and top (1) of the fuel pump module and according to service manual, are not to be replaced unless indicated by diagnostic procedure...they are a lifetime fuel filter
Old Mar 27, 2007 | 11:53 PM
tailgatedrinkin's Avatar
tailgatedrinkin
are the 06 models the same??
Old Mar 28, 2007 | 12:13 AM
FFMedic1479's Avatar
FFMedic1479
They are really lifetime filters? If so, that's pretty sweet.
Old Mar 28, 2007 | 01:25 AM
hemiyellow's Avatar
hemiyellow
DC Insider
i would assume the 06 models are the same, but i dont know for sure....yah the service manual says they are lifetime
Old Mar 28, 2007 | 10:25 PM
deanj287's Avatar
deanj287
how does any filter last a lifetime with out being maintaned?? so if you run ****ty gas and it gets lots of build up where does it go? into your 5 grand motor or stay there and clog the filter...for life?? in all me cars that i have owned every one of them required filter changes at some point. no matter the quality of fuel either! i wish i could spend ten bucks and change the filter to be honest.. the peace of mind that dodge designed a lifetime part is not a good one!!!
Old Mar 28, 2007 | 10:41 PM
Gone Fishin's Avatar
Gone Fishin
You could always add one in line to prevent anything from reaching the engine, but the factory ones are integral with the pump, and if they clog, I do believe it requires the fuel pump, regulator(integral) be changed out to change the filters. I felt the same way with mine, but it is what it is.
One other thing to consider on your 5.7. The regulator is located at the tank, and there is no return line from the injector rail to the tank.
The rails are made out of metal, and have been known to rust, getting flakes into the top screen of the injectors--plugging them.
Run a can of Sea Foam through your tank at each oil change to grab the water and burn it, keeping the tank dry, and the dead leg areas of the injector rails rust free-----plus it keeps the injectors clean and the engine running good.
Just a Heads UP
Old Mar 29, 2007 | 01:23 AM
deanj287's Avatar
deanj287
wat is this sea foam you speak off??
Old Mar 29, 2007 | 01:25 AM
hemiyellow's Avatar
hemiyellow
DC Insider
this stuff right here....... http://www.seafoamsales.com/motorTuneUp.htm
Old Mar 29, 2007 | 01:28 AM
deanj287's Avatar
deanj287
just pore a can in the tank?
