DIY Back Seat Mod
Old Apr 14, 2009 | 06:17 PM
oefootball_70's Avatar
oefootball_70
Default DIY Back Seat Mod
Tools required:channel locks a utility knife, and an 8mm socket. The channel locks are for the torx screws that mount the seat back to the hinge, these are used due to the lack of room to fit any other tools back there.
1) Remove torx screw (using channel locks) holding seat back on either side of seat. (total of 4 on split bench)
2) Pull up on seat back to disengage from hook and pull seat back out.
3) Using 8mm socket, remove catches on the back of the cab.
4) With utility knife, cut sound deadener to make room for upside down catches.
5) Reinstall the catches upside down
6) Reinstall seat backs. (lining up these mounts can be a bit of a PITA but its not too bad) Take your time and line up the bolt right.
Folded normal after
Folded forward after
Mostly done by forumpete, but with touch up help and added photo's by OEFootball_70
Old Apr 14, 2009 | 06:30 PM
MADMAXIN22's Avatar
MADMAXIN22
maybe pics during the day would help... what did this achieve?
Old Apr 14, 2009 | 07:01 PM
oefootball_70
yeah I decided that I need to take new pictures. I am gonna run outside and do it right now. It allows for you to keep an amp back there. Or really whatever you want.
Old Apr 14, 2009 | 07:03 PM
SilverBullet08's Avatar
SilverBullet08
does this raise the seat up alittle bit??
Old Apr 14, 2009 | 07:04 PM
BEAR's Avatar
BEAR
+1 yeah sorry bro but I couldn't make some of the pics out. They were kinda dark, and what did you do this for? I mean what does your seat do now? sorry...
Old Apr 14, 2009 | 07:18 PM
mfs212's Avatar
mfs212
I like not being able to get to the amps....makes em WAY harder to steal.
Old Apr 14, 2009 | 07:20 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Add me to that list. I am sure it is something worthwhile but I can't tell from the pics what exactly we are supposed to be looking at.
Old Apr 14, 2009 | 08:10 PM
Alpheus's Avatar
Alpheus
Its for making the back of the seat fold down. Look at the last pic you can see its folded down...
Old Apr 14, 2009 | 08:28 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
x2 on this one.
Old Apr 14, 2009 | 08:52 PM
Matt99's Avatar
Matt99
Well I just did the mod....Do yall's back seat come off of the wall if you lift the bottom up a few times? I just put in a new sub box, its about 1" above the rests for the bottom of the seat, that might be doing it. The mount for the old torx screw kind of sticks out?
One question....My box doesn't quite fit too well, the seat pushes it down and it wobbles....any ideas?
