Lowered Trucks: tech and info....
#381
i know this sounds stupid and im not insulting your intelligence but was it done right are you sure everything was tightened ? theres gotta be an explanation the rear is not diffic ult to understand its actually simple ....is your truck a 4x2 4x4 what did you use and how did you do it what exactly did you take apart? like i said b4 lots have done this with no problems....just trying to get a feel for the sitiation....feel me.....
#382
#383
#384
what im saying is it doesnt change the angle enough to make a vibration its no different with a load in the rear or a drop of 2" i have used my work truck fully loaded by that i mean squatted out which would lower it lower than 2" and no vibration i just cant see that being the reason for your vibration.....better check your tires
#385
#388
sweet its coming together....im thinking about doing mine...i keep getting flashed like im high beaming ppl and i know im not i dont even have hids? oddd....well slamfest is happening and im not there sadly but life goes on...will haveta look at the site next week to see pics when they post em......
#389
thanks for the comments guys.. it wasnt too bad just alot of patience soap/water and a hair dryer... heat the film up with the hair dryer and it helps stretch and get all the creases out.. idk about the heads with the rounded bottoms bc i have the new headlights (08) but all in all it wasnt too bad about 1 1/2 hours a piece.
#390
