Is the overhead MPG readout accurate?
Old Jul 30, 2009 | 02:02 PM
matt1048's Avatar
matt1048
Default Is the overhead MPG readout accurate?
Has anyone tested the overhead MPG read out compared to the actual gallons of fuel to the distance traveled by the odometer? Is it pretty close?
Old Jul 30, 2009 | 02:05 PM
BEAR's Avatar
BEAR
Mine is with in .3
Old Jul 30, 2009 | 02:11 PM
hontzy87's Avatar
hontzy87
I don't think mine is accurate. It always starts to average out then i gotta keep resetting it, unless i'm doing it wrong. I gotta try it on my next full tank.
Old Jul 30, 2009 | 02:51 PM
disturbedgator's Avatar
disturbedgator
mines way off.... it says im gettin 11 mpg, but since i installed a super hightech wing that is guaranteed to get me 30 mpg i know its wrong. i just use it for temp and direction
Old Jul 30, 2009 | 03:01 PM
Dodgeboy77's Avatar
Dodgeboy77
it does average. if you want to know right at the minute you have to reset it and watch.
Old Jul 30, 2009 | 03:51 PM
SMKNRAM's Avatar
SMKNRAM
Mine is off by about 1.5 mpg on the avg eco. the odometer is right but you should manually check it at fill up. also if you watch the eco setting it will tell you the current as you go mpg
Old Jul 30, 2009 | 04:55 PM
santafehemi's Avatar
santafehemi
mine is off. could it be that i havent calibratated the computer for the bigger tires. there are some that will say the are not accurate.
Old Jul 30, 2009 | 05:21 PM
hontzy87's Avatar
hontzy87
Yo where did you get the wing! I want that! I don't see it in your pics tho haha
Old Jul 30, 2009 | 05:28 PM
04-fourseven's Avatar
04-fourseven
hahahaha, super hightech wing, freakin rock-n-roll man!!!
My overhead is usually right on. You have to let it run throughout the whole tank, and make sure to reset it everytime you fuel up. Even if you dont put in a full tank. I havent calculated mine for a few tanks, but I usually do when I go on long trips. Ive always been within .3 of the overhead display.
Old Jul 30, 2009 | 06:05 PM
jfrerichs89's Avatar
jfrerichs89
my comp has been very close, prolly off by .1 - .3. If you have tires that are any size different than stock and its not calibrated then it should be off but other than that all the dodge trucks my family has owned are usually pretty close with the overhead display too.
