Radiator Leaking
Old Jan 14, 2010 | 09:33 PM
Hessmonster's Avatar
Hessmonster
Default Radiator Leaking
Has anyone replaced their radiator. Mine has a leak and I'm going to try and do it myself..Any tips or tricks?
Old Jan 14, 2010 | 09:47 PM
hemiguy0302's Avatar
hemiguy0302
where is yours leaking from?
Old Jan 14, 2010 | 09:54 PM
AF_HEMI's Avatar
AF_HEMI
i've got a used one with 25k miles i just took off. I'd be happy to sell it to you cheap if you're interested. PM me. install is cake. jut did it myself a couple months ago
Old Jan 14, 2010 | 09:55 PM
Brokenpath's Avatar
Brokenpath
Radiator replacement on almost any vehicle is very simple and easy.
Unhook the lower radiator hose, and drain. (It's not legal in a lot of places to do that so have a bucket or do it in a private area.)
Next just unscrew and unhook everything (Remove fan shroud.)
If you REALLY want to go all the way you can flush the system with antifreeze since you have everything unhooked. I used to just use a water hose where the thermostat goes and flush it all out but some people might to do it with 50/50 mix.
Get the new radiator and rebolt and re-fill fluids.
Since you have it all apart you can probably opt for an aluminum radiator or some electric fans.
Old Jan 14, 2010 | 10:44 PM
Hessmonster
Its leaking on the drivers side near the bottom
Old Jan 14, 2010 | 10:46 PM
Hessmonster
Why did you replace it?
Old Jan 14, 2010 | 11:27 PM
Brokenpath's Avatar
Brokenpath
post pics when you do it please.
Also, it can be anything.
A pressure test will figure that out very quickly. You can usually borrow them for free at any big auto parts store like kragen or auto zone.
You basically hook it up to where the cap is then see if the PSI drops from the guage, then you can stick your head in there and try to hear where it's coming from if it's leaking.
Check ALL fittings and make sure they're tight, it can be water coming from anywhere dripping down to that area.
also, please never use stop leak.
Old Jan 14, 2010 | 11:51 PM
hemiguy0302
Mine is leaking ever so slightly from the pinch seam on the drivers side. NOt leaking enough to make me worry yet so I will replace/flush this summer when I get making some money again.
Old Jan 15, 2010 | 12:10 AM
Brokenpath's Avatar
Brokenpath
yeah if it's not that bad a simple check of the coolant tank here and there and keeping the fluids topped off usually does her good until you replace it.
Old Jan 15, 2010 | 05:37 AM
Kamel87's Avatar
Kamel87
i have an extra radiator for an 03 4.7l so idk if it will fit but if it does ill sell it cheap to you if u want it. its brand new
