Radiator Leaking
Old Jan 15, 2010 | 08:05 AM
AF_HEMI's Avatar
AF_HEMI
i changed mine out because my thermostat was bad and i thought it was the radiator. put the new radiator in and it didnt fix the problem, therefore the old one was still good.
Old Jan 15, 2010 | 09:58 AM
cwboyjohnny24's Avatar
cwboyjohnny24
Originally Posted by hemiguy0302
Mine is leaking ever so slightly from the pinch seam on the drivers side. NOt leaking enough to make me worry yet so I will replace/flush this summer when I get making some money again.
Mine is leaking VERY slowly from the exact same place too!
Old Jan 23, 2010 | 02:57 PM
Hessmonster's Avatar
Hessmonster
How much does a new one cost?
Old Jan 23, 2010 | 07:41 PM
EvlKenevl's Avatar
EvlKenevl
I paid $195 up here in Canada(stealership wanted $470). I also replaced thermostat cuz Iread some where on here that it was causing the pressure problem (heater core went first).
It was pretty simple to change, start with draining from lower rad hose, then take the overflow tank and wiper fluid tank off. there is about 6 bolts to take out and its out. I missed the rubber mount on the old rad when installing the new rad, it was stuck on the bottom of the old rad( passenger side).
EASY PEAZY JAPANEEZY!
Old Jan 24, 2010 | 04:50 AM
Kamel87's Avatar
Kamel87
fyi if u want one ill do it 150 shipped
Old Feb 2, 2010 | 06:08 PM
olsen185's Avatar
olsen185
I have the same exact leak on my 97 1500. It seems to be coming from the area of the drain/ endtank. Rock auto sells new ones for $107 http://www.rockauto.com/catalog/rafr...1095746k271614.
