Problem with my ram !!!!!
Old Jan 31, 2010 | 09:16 PM
JoeHemi's Avatar
JoeHemi
Originally Posted by Off_Road_Teacher
Needing a scanner to pull a code is always a great excuse for buying a tuner.
LOL yup, except I went to harbor freight and bought one for 15 bucks...but now I have a backup!
Old Jan 31, 2010 | 10:42 PM
Bi0sC0mp's Avatar
Bi0sC0mp
i am new to this how you do the key code thanks for all the help
Old Jan 31, 2010 | 11:02 PM
cheapbeater's Avatar
cheapbeater
https://dodgeforum.com/forum/3rd-gen-...ine-codes.html
Old Jan 31, 2010 | 11:51 PM
red cross bones's Avatar
red cross bones
My 2010 laramie crew has a whirling noise coming from underneath truck and gets worse after 1o minutes. It is not there on start up in morning. Technician says it could be Catalytic converter back pressure.I only have 2600 miles on it and it did not make this mnoise in the first 1000 miles.No lights on dash but mileage is getting worse.Anyone have any thoughts?
Old Feb 1, 2010 | 07:28 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
has the dealer looked at it? With it being a 2010 and 2600 miles, it would be on thier rack by now.
Old Feb 1, 2010 | 07:30 AM
JoeHemi's Avatar
JoeHemi
Hey Redcross, I recommend posting a new thread in the 4th gen section. They may be able to help you more with your issue. Also, warranty should cover it.
Old Feb 1, 2010 | 09:15 AM
Bi0sC0mp's Avatar
Bi0sC0mp
i tried doing that key code thing it dont work so will take it and have it out on a computer
Old Feb 2, 2010 | 06:15 AM
Bi0sC0mp's Avatar
Bi0sC0mp
Thanks for all your help i figured it out.. took it to advanced and had them put it on the scanner it throw a code for the egr valve so picked one up while i was there and will install it this weekend thatnks alot for all your help and advice..
Old Feb 2, 2010 | 07:35 AM
JoeHemi's Avatar
JoeHemi
Wow, surprised they actually had one in stock. When I replaced mine, not a single advance or autozone in Virginia had the EGR in stock or in the warehouse. The EGR is a common problem with the trucks. I recommend when you change it out, remove the airbox so you have room to work.
Old Feb 2, 2010 | 07:38 AM
JMB3384's Avatar
JMB3384
I am glad to hear that you got it figured out. The check engine light could be a 1 of tons of things, usually something simple. I had it come on in my 03' 2500 and all that set it off was a loose gas cap according to a tech at the Jag dealership I worked at. A new one solved the problem!
